The Xiaomi 15T Pro stands as one of Xiaomi’s most ambitious flagships to date, blending cutting-edge performance with Leica-powered imaging excellence. With its triple-lens camera system, blazing-fast MediaTek Dimensity 9400+ processor, and vibrant 6.83-inch AMOLED display, this device is clearly built for creators, professionals, and anyone who demands more from their smartphone.
Better yet, you don’t need to break your piggy bank to enjoy flagship performance. The Dimensity 9400+ is every bit as powerful as Qualcomm’s Snapdragon 8 Gen 3, delivering smooth multitasking, console-level gaming, and lightning-fast AI processing without compromise. The camera system is where it really shines: the 5x optical zoom is super crisp and clear, easily rivaling dedicated zoom cameras. That said, pushing zoom all the way up to 100x will definitely need stronger AI enhancements to consistently deliver sharp, detailed results. And if you plan to take full advantage of HDR10+ video recording, be prepared to pair it with a proper video editor that can handle the format—otherwise, those vibrant clips may not look their best.
Battery life and charging are equally impressive, thanks to the large 5500mAh cell supported by 90W wired and 50W wireless charging. On top of that, HyperOS with HyperAI elevates productivity and everyday use, while the new Xiaomi Astral Communication feature adds a unique twist—modern walkie-talkie-style calls without needing a network.
Wrapped in a sleek, premium design with IP68 durability, the Xiaomi 15T Pro proves it’s not just another flagship—it’s a complete package that balances power, photography, and practicality. For those seeking a smartphone that delivers on all fronts, the 15T Pro deserves a spot at the very top of the list.
Leica-powered triple camera system
MediaTek Dimensity 9400+ flagship performance
6.83-inch AMOLED display, 144Hz, 3200 nits
5500mAh battery, 90W wired & 50W wireless charging
100x zoom needs stronger AI
HDR10+ video editing requires third party software
No telemacro lens
Large size, less pocket-friendly
Pricing information
Price and availability
Xiaomi 15T Pro comes in 2 variants, and is priced at: 12GB + 256GB (SGD799) and 12GB + 512GB
(SGD899).
Xiaomi 15T will be available in 12GB + 256GB (SGD599) and 12GB + 512GB (SGD699).
Pre-orders will begin from 25 September to 10 October 2025.
The Xiaomi 15T Series is available on Xiaomi Store, mi.com, Shopee, and Lazada.
