AMD demonstrates AMD Eyefinity Technology
AMD A-series platform
Bluetooth 18 Dec 2012
Christmas is round the corner, have you decided what platform is the most cost effective solution out there? Last year, AMD delivered the first APU LIano which delivers integrated graphics into the core. This October, AMD delivered the 2nd generation that is built on the strength of the earlier generation.
IMG_7076 copy
If you have read our reviews, you would have noticed how well the Trinity or A10-5800K performs especially in the graphics performance against even the high end Intel Core i5-3570K. So what has changed ?
Basically, the the new A-series plaform Socket FM2 features the new X86 architecture featuring the “Piledriver” cores. Some features of it includes supports up to 4 cores and latest ISA instructions including AVX, AES, XOP, FMA4/3. There is also enahnced cache performnce over the previous BullDozer cores. It has also improved it’s max turbo frequency to up to 4.2GHz and is configurable through AMD Overdrive.
The GPU is also improved and feature 384 shaders at 800MHz, It supports 8xAA and 16AF  and DX11 support. UVD and VCE allows video encode and decode hardware to offload CPU and AMD Picture Perfect support with HD post processing technologies are included in this new design.
For those who always do file compression using WINZIP, you can also take advantage of the OpenCL instructions. One of such application is WinZip 16.5 x64 build 10095. Another such application is Cyberlink PowerDirector ver 11.
In fact, something that most users overlook is the support of new display technologies. This new platform comes with AMD Eyefinity technology that can support 3+1 monitors and has Display Port 1.2 support.. In addition, it has AMD Dual Graphics enhancements that allows you to pair up with an external graphics card to boost the graphical performance.
Comments are closed.
