Make PC DIY more colourful by adding the AORUS RGB memory modules.
Explore the full spectrum of glorious RGB Lighting with AORUS RGB Memory and Exclusive RGB Infused Demo Modules.
Seamless RGB synchronization between the motherboard and other peripherals
AORUS RGB Memory supports 11 lighting modes. 5 are new lighting modes only for the AORUS RGB Memory. Color strobe, Cascade, Color Cascade, Droplet and Color Droplet are the new modes that adds unique style to your system.
RGB Fusion is GIGABYTE’s utility to customize the lighting effects of the devices with RGB LEDs on your system. Now it is 100% compatible with the AORUS RGB Memory kit, offering multiple new features. The new UI design is more user friendly and easy to work with. Users now can adjust the speed and brightness of the flashing light on the application’s built-in scale. Create your own personal profile to fit different style.
Memory Size : 16GB Kit (2 x 8GB)
Frequency : DDR4-3200 MHz
Timing : 16-18-18-38 (XMP 3200MHz)
Voltage : 1.35V (when XMP enable)
Memory IC : Samsung B-Die
RGB Fusion supported
100% Sorted & Tested
High efficient heat spreaders to keep performance
Performance Profile : XMP 2.0
User Friendly Design for Easier Installation
Lifetime Warranty
Comply with industrial standard JEDEC DDR4
