ASRock showcase 8 new upcoming Intel Sandy Bridge boards – P67 Extreme4, P67 Extreme6, P67 Pro, P67 Pro3, H67M GE-HT, H67M GE, H67M, H67DE3
The company has planned for eight models, four ATX based on the P67 chipset along with one ATX  and three  mATX on H67.
ASRock has every segment covered with two enthusiasts focused units, the P67 Extreme6 which packs six SATA 6Gbps ports, six USB 3.0 (4 external, 2 internal), three PCIe 2.0 x16 slots, and an 18-phase CPU VRM.
The slightly lessened (and likely slightly cheaper) P67 Extreme4, has – you guessed it – four SATA 6Gbps ports, four USB 3.0 (two ext. two int.), PCIe 2.0 x16 slots, and a few changes to layout and connections.
asrock p67 extreme6 300x192 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
asrock p67 extreme4 300x217 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
The two consumer level models, the P67 Pro and Pro3, include just a single PCIe x16 slot, three PCIe x1 and three PCI connections. While the Pro3 still includes two SATA 6Gpbs ports, two USB 3.0 external connections, and a still impressive 10-phase CPU VRM, the base Pro model does away with USB 3.0, keeps the two SATA 6Gbps, and features only a 4+1 phase VRM.
asrock p67 pro3 300x185 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
asrock p67 pro 300x183 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
On the mATX side of things, the H67M GE-HT is the premium model, with four DDR3 DIMM slots, 6-phase VRM, four USB 3.0, two SATA 6Gbps, and external video connections including DVI, D-Sub, HDMI 1.4a, and DisplayPort.
The H67M GE is a trimmed version, without VRM heatsinks, Displayport connector and no internal USB 3.0. Lastly the  consumer H67M, which in every ways similar, but only features only two DDR3 DIMM slots and thus is slightly thinner as well.
asrock h67m ge ht 300x191 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
asrock h67m ge 300x191 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
Interestingly, ASRock has also chosen to build an ATX motherboard based on the H67 chipset; the H67 DE3. This allows users to get the Intel Flexible Display Interface (FDI) output with a full-sized ATX motherboard. In features, the board is identical to the rest of the H67 line, but the added length allows for an additional PCI and PCIe x1 slot.
asrock h67m 300x191 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
asrock h67 de3 300x181 ASRock Showcases LGA 1155 Sandy Bridge  Motherboards
