ASRock USB 3.0 Card
ASRock USB 3.0 Card allows you to enjoy the high speed data transfer rate up to 5.0 Gb/s, which is ten times faster than current USB 2.0 standard (480 Mb/s). With two USB 3.0 ports on ASRock USB 3.0 Card, you can enjoy USB 3.0 super speed.
![]() Ultimate Data Transfer Speed
Delivering data transfer rates up to ten times faster than USB 2.0 with optimized power efficiency, USB 3.0 card features super speed at 5 Gb/s. ![]() Upgrade Flexibility
Utilizing the new generation USB3.0 interface, ASRock USB 3.0 card includes much advantages, such as higher data transfer speed and more flexible to adopt in different ASRock motherboards. |
Specifications
General | |
Chipset | – NEC µPD720200 |
Interface | – PCI Express 2.0 x1 |
Connector | – 2 x USB 3.0 ports |
OS | – Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant |
The specification is subject to change without notice in advance. The brand and product names are trademarks of their respective companies. Any configuration other than original product specification is not guaranteed.
