August. 4, 2010, Taipei, Taiwan – ASRock Inc., the global leading motherboard manufacturer, is pleased to announce the latest AMD 890GX motherboard – 890GX Extreme4. ASRock Extreme4 series motherboards target to serve the high-end market and offer more than enough USB 3.0 and SATA3 connectors. The well-featured 890GX Extreme4 motherboard comes with 4 SuperSpeed USB 3.0 ports (2 on free-bundled Front USB 3.0 Panel, 2 on back panel) and 5 SATA3 ports; it is also the first AMD 890GX motherboard supporting ASRock unique Front USB 3.0 technology in the world.
Based on the AMD 890GX and SB850 chipsets, ASRock 890GX Extreme4 delivers the versatile HD visual performance and OC value to users! The ASRock 890GX Extreme4’s four DIMM slots support up to 16GB of DDR3 RAM at up to 1866MHz, and three PCI-E 2.0 X16 slots are capable of running multi-GPU setups (ATITM Quad CrossFireXTM, 3-Way CrossFireXTM, CrossFireXTM and Hybrid CrossFireXTM). The real I/O has two USB 3.0 and four USB 2.0 ports, one eSATA3, one HDMI, one D-Sub, one DVI-D, Gigabit Ethernet, 7.1 CH HD Audio with THX TruStudio PRO support and one Clear CMOS switch with LED. You also get onboard power and reset buttons and a two-digit LED POST display (Dr. Debug). In addition, ASRock 890GX Extreme4 was built with 100% Japan-made high quality capacitors. The all solid capacitor design enhances the board’s stability and reliability. With its new AMD 890GX chipset, the ASRock 890GX Extreme4 also includes an integrated ATI Radeon HD 4290 graphics core capable of decoding Full HD 1080p video. All important components can be found here, 890GX Extreme4 mainboard is clearly the one for enthusiasts!
Moreover, this board is equipped with one Front USB 3.0 Panel that supports two additional USB 3.0 ports besides the rear I/O panel. Just simply connect the Front USB 3.0 Panel between the front USB 3.0 header on the motherboard and chassis, users can enjoy a much more convenient computing environment!
For software tool, 890GX Extreme4 supports all ASRock unique software, such as OC DNA, OC Tuner, Instant Flash… and so on. Special introduce here is the Turbo UCC function. Turbo UCC technology, exclusive from ASRock, helps you to unlock the hidden CPU cores in the CPU, boost up the system performance automatically and save energy all together.  It is an all-in-one solution that provides user an energy-saving overclocking and CPU upgrading process. With the innovative Turbo UCC, ASRock 890GX Extreme4 can easily upgrade the system performance higher than its normal standard!
Despite all this, ASRock 890GX Extreme4 provides true studio audio experience with THX TruStudio PRO solution. THX TruStudio PRO is specially designed to bring the same great audio experience found in live performances, films, and recording studios – to the PC. THX TruStudio PRO ensures you the unparalleled audio quality, effects and features for PC systems equipped with onboard audio. With THX TruStudio PRO, ASRock 890GX Extreme4 can provide you the high-quality audio experience.
ASRock 890GX Extreme4 offers interesting functions too. The ASRock AIWI utility enables you to play the games by holding your iPhone or iPod touch. ASRock AIWI redefines the PC gaming operation. It turns your iPhone or iPod touch into a game joystick. All you have to do is just to install the ASRock AIWI utility either from ASRock official website or ASRock software support CD to your motherboard, and also download the free AIWI Free from App store to your iPhone/iPod touch. Connecting your PC and apple devices via Bluetooth or WiFi networks, then you can start experiencing the exciting motion controlled games!
890GX Extreme4 (Brief Specification)
– Support for Socket AM3 processors: AMD PhenomTM II X4 / X3 / X2 (except 920 / 940) and Athlon II X4 / X3 / X2 processors
– ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
– Advanced V8 + 2 Power Phase Design
– Dual Channel DDR3 1866(OC), non-ECC, un-buffered memory, 4 x DIMM slots, Max. capacity up to 16GB
– 3 x PCI Express 2.0 x16 slots, 1 x PCI Express 2.0 x1 slot, 3 x PCI slots
– ATITM Quad CrossFireXTM, 3-Way CrossFireXTM, CrossFireXTM and Hybrid CrossFireXTM
– Integrated AMD Radeon HD 4290 graphics, DX10.1 class iGPU, Shader Model 4.1
– Built-in 128MB DDR3 1333/1200MHz SidePort Memory
– Multi-VGA output options: D-Sub, DVI-D and HDMI
– 5 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1 and RAID 5)
– 2 x Rear USB 3.0 ports by NEC MPD720200, support USB 1.0/2.0/3.0 up to 5Gb/s
– 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by NEC UPD720200, supports USB 1.0/2.0/3.0 up to 5Gb/s
– PCIE x1 Gigabit LAN 10/100/1000 Mb/s
– Power/Reset/Clear CMOS Switch with LED, Dr. Debug,
– 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), supports Blu-ray audio and THX TruStudio Pro
– Supports ASRock OC DNA, OC Tuner, IES, Instant Boot, Instant Flash, AIWI, APP Charger, Turbo UCC, Multi-Speed Fan Control
– Free Bundle: 1 x Front USB 3.0 Panel
For more product info, visit us on http://www.asrock.com.
