ASUS MB168B+ portable 15.6″ USB powered monitor Review
Bluetooth 26 Feb 2015
Price (US) : $294
Price (UK) : £178.95
Are you a mobile worker that works on the notebook and prefer to view your presentations or spreadsheets on a larger screen. Is that possible at all unless you are glued to the office desk with a LCD monitor with HDMI input. Oh! Wait a minute, if you are still using your older notebooks, there is a high chance that they don’t even come with a HDMI port! How are you going to hook it up to a LED monitor?
IMG_0135 copy IMG_0133 copy
Well, thanks to the advancement of technology, ASUS has developed the MB168B portable HD screen. This slim 15.6″ Full HD screen is powered by USB. Effectively, you do not even need a power bank to power it up as it taps the USB power through the USB 2.0 or USB 3.0 port on your notebook. With the leather case which also serves as the stand, the MB168 auto rotates between landscape and portrial mode based on it’s position. It also automatically adjusts itself to the ambient environment to reduce eye glare. On the next page, we take a look at the setup of this device.
Price (US) : $294
Price (UK) : £178.95 IMG_0136 copy   Specifications Display
Panel Size: Wide Screen 15.6″(39.6cm) 16:9 Panel Type : WLED/ TN True Resolution : 1920×1080 Full HD 1080P : Yes Pixel Pitch : 0.179mm Brightness(Max) : 250 cd/㎡ Contrast Ratio (Max) : 600:1 Viewing Angle (CR≧10) : 140°(H)/120°(V) Response Time : 11ms
  • Convenient Hotkey
    Brightness Adjustment
  • I/O Ports
    USB Port(s) : 3.0
  • Power Consumption
    Power Consumption(Typical):<5W Power Saving Mode:0W Power Off Mode:0W
  • Mechanical Design
    Chassis Colors : Silver+Black Slim Design : Yes
  • Dimensions
    Phys. Dimension(WxHxD):379x236x8mm Box Dimension(WxHxD):435x297x57mm
  • Weight
    Net Weight(Esti.):0.8kg Gross Weight(Esti.):2.0kg
  • Accessories
    ASUS Smart Case USB 3.0 cable Quick start guide Support CD
