ASUS Republic of Gamers Announces Maximus VII Formula Series
ROG’s Z97 ATX gaming motherboard is engineered with exclusive CrossChill Copper hybrid cooling, flawless SupremeFX Formula 2014 audio, double-sided ROG Armor covers and Watch Dogs game bundle
Singapore (30th July, 2014) — ASUS Republic of Gamers (ROG) today announced Maximus VII Formula and Maximus VII Formula/Watch Dogs, Z97 chipset-based ATX gaming motherboards ready for the latest 4th-, new 4th- and 5th-generation Intel Processor.
Maximus VII Formula delivers the best gaming hybrid-cooling solution with CrossChill Copper, the best gaming audio with SupremeFX Formula 2014 and the best gaming networking with Intel Gigabit Ethernet, GameFirst III and LANGuard. The new motherboard also has the best gaming power solution with Extreme Engine DIGI+ III and TrueVolt 5V, and the best gaming protection with ROG Armor, premium components, ESD Guards and a multitude of DIY-friendly design innovations.
Maximus VII Formula_3D-2 Maximus VII Formula_3D-1
Best gaming hybrid cooling
The best gaming performance means keeping cool, so ROG has equipped Maximus VII Formula with the all-new and exclusive CrossChill Copper hybrid-cooling solution.The CrossChill Copper’s broad array of internal fins maximize the cooling channel’s heat-dissipation surface area for extreme thermal efficiency. With liquid, MOSFET temperatures are lowered by up to 23˚C and the G1/4-inch threaded fittings mean that Maximus VII Formula offers maximum compatibility for existing cooling setups — just fit the barbs, attach the pipes and it’s good to go.
Best gaming audio
Maximus VII Formula introduces SupremeFX Formula 2014, the integrated-audio solution that’s as great as a dedicated sound card. Cutting-edge isolation technologies minimize electromagnetic interference (EMI) and exceptionally-premium components deliver best-in-class audio, with an outstanding 120dB signal-to-noise ratio (SNR) and Cirrus Logic® CS4398 digital-to-analog converter (DAC) available via the rear output.
From the stylish black nickel EMI cover and warmth-suffusing ELNA® and WIMA® film capacitors to the high-fidelity Texas Instruments LM4562 operational amplifier that drives up to 600ohm-impedance headphones via the rear output. SupremeFX Formula 2014 also includes exclusive Sonic SenseAmp technology to automatically detect analog-audio front-panel (AAFP) headphone impedance and adjust the built-in amp, while Sonic SoundStage applies the best audio settings for popular game genres and Sonic Studio enables brilliant 7.1-channel virtual surround sound with just one click.
Best gaming networking
Maximus VII Formula is also fitted with state-of-the-art Intel Gigabit Ethernet that delivers better throughput with lower processing power for superior speed and increased efficiency. The new motherboard’s networking capabilities additionally benefit from ROG-exclusive GameFirst III technology for no-delay gameplay.
ROG has even reinvented the RJ45 socket, with LANGuard. Advanced signal-coupling technology and premium surface-mounted capacitors improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect against lightning strikes and static-electricity discharges.
Best gaming power solution
Maximus VII Formula’s Extreme Engine DIGI+ III voltage-regulator module (VRM).
NexFET MOSFETs deliver up to 90% efficiency in normal operation; they’re also more durable and half the size of standard MOSFETs. 60A BlackWing chokes serve up power with minimal loss and at very low temperatures, while Japanese-made 10K black metallic capacitors last five-times (5X) longer and deliver 20%-greater endurance at extreme temperatures than generic capacitors — ensuring that Maximus VII Formula is able to withstand even the hardest of hardcore gaming.
Best gaming protection
Maximus VII Formula is brimming with some brilliantly innovative features to protect both gamers and their gaming gear. Exclusive ROG Armor is a two-part fortification that compromises a strong and stylish ABS-plastic cover and a SECC (steel, electro-galvanized, cold-rolled coil) backplate. The ABS cover blocks heat from the graphics card, lowering system temperatures for better performance; and the SECC backplate supports the motherboard to prevent bending, employing thermal pads to efficiently conduct heat away from crucial components.
AVAILABILITY & PRICING
Models ROG Maximus VII Formula
Selling Price (SGD) $569
Availability NOW
