Intro
Contents
Are you frequently confronted with the inconvenience of reaching the power outlet to connect your charger for charging your laptop, smartphone, or other USB gadgets? Worry not, as the Belkin BoostCharge offers a solution. Thanks to the long power cord, with its 4-port charger, you can now conveniently position it on your workbench, providing effortless access to four charging ports.
Available on Amazon at USD 76, Shopee S$129
The Belkin BoostCharge Pro4-Port GaN Charger 108W might be your answer. The 4-port GaN charger boasts a combination of 2 USB-C and 2 USB-A ports, allowing you to conveniently charge multiple devices. With a total power output of 108W, you can power up to four devices simultaneously. Thanks to the integrated GaN technology, this charger delivers a high-power and efficient charge.
Utilizing USB-C PD 3.0, you can recharge your MacBook Pro from 0-50% in just 39 minutes*. Alternatively, you can achieve the same 0-50% charge for an iPad in 39 minutes and for an iPhone 14 Pro in 26 minutes†. The charger’s Intelligent Power Sharing feature aptly recognizes the power requirements of connected devices and accurately distributes the appropriate output to all four devices.
The left most two ports delivers a max of 96W or 65W+30W and the two other USB-A ports on the right shares 12W in total. At one time you can charge up 4 devices, 2 with USB-C and another 2 using USB-A cables.
The charger supports USB-C PD charging and is compatible with the following devices.
- iPad 9th gen
- iPad Air
- MacBook Pro
- MacBook Air
- iPad mini
- iPad mini 6th Gen
- Apple Watch Series 7
- Dell XPS 15 9570
- Google Pixel 5
- iPad Pro
- iPhone 14
- iPhone 14 Pro
- iPhone 14 Plus
- iPhone 14 Pro Max
- iPhone 11
- iPhone 11 Pro
- iPhone 11 Pro Max
- iPhone 12
- iPhone 12 mini
- iPhone 12 Pro
- iPhone 12 Pro Max
- iPhone 13
- iPhone 13 mini
- iPhone 13 Pro
- iPhone 13 Pro Max
- iPhone SE 2nd Gen
- ThinkPad L380
- Yoga 930
- Galaxy S20
- Galaxy S20+
- Galaxy S20 Ultra
- Galaxy S21 5G
- Galaxy S21+ 5G
- Galaxy S21 Ultra 5G
- Galaxy S23
- Galaxy S23 Plus
- Galaxy S23 Ultra
- Galaxy Note20
- Galaxy Note20 Ultra
