Biostar introduces two ivy bridge boards based on Intel Z75 chipset – TZ75A and TZ75B
Although most manufacturers are promoting their high end Z77 chipset mainboards, the budget conscious users will also want to take a look at the Z75 chipset mainboard suitable for pairing up with the upcoming Ivy Bridge processors. Both boards have very similar specifications except the following.
TZ75A uses Realtek ALC892 8 ch HD audio whereas TZ75B comes with 6 channel Blu Ray audio.
TZ75A is larger with a dimension of 30.5cm x 24.4cm while TZ75B dimension is 29.5cm x 23 cm.
TZ75A supports Rapid Switch while TZ75B supports Rapid Switch2.
BIOSTAR TA75A
•Support the Intel 3rd and 2nd generation Core i7 and Core i5 processors in the 1155 package
•Intel Z75 single chip architecture
•Support 4-DIMM DDR3-2133(OC)/1866(OC)/1600/1333 up to 32G maximum capacity
•Support SATA 6Gb/s 2X speed than current SATA 3G
•Support USB 3.0
•100% X.D.C solid capacitor
•BIOSTAR G.P.U (Green Power Utility) Technology for Energy Saving
•BIOSTAR Toverclocker utility
•8 Phase power
BIOSTAR TZ75B
•Support USB 3.0
•6 Phase power
