ASUS Showcases Home Computing, Professional Displays, Mobile Projectors and Networking Innovations at 2015 CES
Singapore (6th January, 2015) — ASUS today showcases at 2015 International CES® its latest line-up of world-class innovations for home and professional use. The diverse line-up of new products includes a mini PC for the home, professional and commercial displays and projectors, along with networking solutions for homes and offices.
Stylish and elegant home computing
ASUS adds a touch of minimalist elegance to home computing with the elegant pearl-white VivoMini UN62 ultra-compact desktop and Designo Series MX27AQ display.
ASUS VivoMini UN62 has been meticulously crafted to blend in with any home environment. It features clean, precise lines, a Zen-inspired concentric circle finish, and measures just 131 x 131 x 42mm, giving it a footprint smaller than a CD jewel case. Despite its compact size, VivoMini UN62 gives users responsive and energy-efficient Intel® Core processor performance for productive everyday computing and detailed 4K/UHD video playback. Extensive connectivity and expansion options let VivoMini UN62 function as a digital hub to give users fast and easy access to stored data and media files. High-speed 802.11ac Wi-Fi, together with exclusive ASUS Wi-Fi GO! and Media Streamer apps, give users full media streaming functions and remote access to VivoMini, making it an ideal addition to any media center or home theater set-up.
ASUS Designo Series MX27AQ has a backlit LED panel that provides native 2560 x 1440 WQHD visuals, and Advanced High Performance In-Plane Switching (AH-IPS) display technology for wide viewing angles with no color shift even when viewed from extreme positions.
This display features an edge-to-edge frameless design with a bezel thickness of only 0.8mm. It has an award-winning sundial-inspired stand which provides a sturdy base for the display to rest on.
ASUS SonicMaster, incorporating ICEpower® technology, provides premium, immersive audio through MX27AQ’s built-in 3W stereo speakers. There is also ASUS Eye Care technology with Low Blue Light and Flicker-free features that prevent eye fatigue and strains.
Professional-grade displays for business and commercial use
ASUS PA328Q 4K/UHD display
Designed for professionals, ASUS PA328Q 4K/UHD is a 32-inch, 16:9 aspect ratio display with native 3840 x 2160 resolution and a pixel density of 138ppi — four times the pixel density of Full HD (1920 x 1080) for more detailed visuals and larger onscreen workspace.
PA328Q is factory pre-calibrated to give industry-leading color accuracy (∆E ≤ 2), with a wide color gamut for 100% sRGB color reproduction and Rec. 709 color space support — the latter being the standard HDTV format for video production and editing.
PA328Q has extensive connectivity options that include DisplayPort 1.2, mini-DisplayPort 1.2, HDMI 1.4, and HDMI 2.0 / MHL 3.0 for true 4K/UHD content support at refresh rates of up to 60Hz. The HDMI 2.0 / MHL 3.0 port even provides HDCP 2.2 copy protection.
The ergonomically-designed PA328Q features a quick-release stand for convenient and easy setup. It also has a full range of swivel, tilt, pivot and height adjustments to provide users with an ideal viewing position.  PA328Q is a recipient of a 2014 Red Dot Award for its outstanding design.
ASUS HA2402 clinical review display
ASUS HA2402 clinical review display delivers true 2.3MP, 1920 x 1200 resolution content for crystal-clear medical imagery, and uses an IPS panel for wide viewing angles on both horizontal and vertical planes. HA2402 is compliant with the Digital Imaging and Communications in Medicine (DICOM) Part 14 standard and is compatible with the Picture Archiving and Communication System (PACS). It has five image modes for improved viewing of medical images ranging from X-rays, CT scans, or MRIs.
HA2402 is ergonomically designed and has a full range of swivel, tilt, pivot and height adjustments, and is VESA wall mount compatible.
SE465-Y digital signage
ASUS SE465-Y digital signage display has a built-in USB player and 3GB internal storage for true plug-and-play convenience; and supports a variety of media files, along with MS Office and PDF file formats.
In-Plane Switching (IPS) technology gives SE465-Y wide viewing angles, with vivid Full HD 1920 x 1080 resolution visuals and 500cd/m2 brightness. It also has built-in 10W stereo speakers for powerful sound delivery.
Presentations made easy
ASUS P3B battery-powered portable LED projector
ASUS P3B is a portable, battery-powered short-throw projector with a lightweight, compact design that easily fits in a briefcase or bag. P3B features an LED light source with a 30,000-hour lifespan and provides crisp HD 1280 x 800 resolution projections at a maximum brightness of 700 lumens. A 0.8:1 short-throw lens lets the P3B project 58-inch diagonal images just one meter away from the projection surface.
P3B works with ASUS Wi-Fi Projection — an easy-to-use app that enables users to wirelessly project and stream content stored in their mobile devices through a Wi-Fi network. P3B lets users conduct presentations without a PC, with HDMI / MHL (Mobile High-Definition Link) video inputs for maximum flexibility with projection sources; MHL also charges connected MHL-enabled smartphones and tablets when projecting. P3B can also double as a 12,000mAh power bank to charge mobile devices.
ASUS ultra-bright B1MR wireless projector
ASUS B1MR wireless projector delivers incredibly sharp HD 1280 x 800 resolution visuals at a maximum brightness of 900 lumens. It features ASUS Wi-Fi Projection for wireless presentations and media streaming; and works without a PC thanks to multi-format file compatibility plus a built-in SD card reader and USB port. Built-in 2W ASUS SonicMaster speakers provide premium sound delivery.
ASUS MB169B+ portable USB monitor
Designed for those constantly on-the-go, ASUS MB169B+ is the world’s slimmest and lightest USB-powered 15.6-inch IPS Full HD monitor. It features a sleek, metallic finish and utilizes a single USB 3.0 cable for power and data transmission.
Fast and stable networking performance
ASUS RT-AC3200
ASUS RT-AC3200 is a tri-band 802.11ac router with the exclusive tri-band Smart Connect feature. Smart Connect ensures that all connected devices do not hinder each other; and allows them to operate at their maximum speeds by automatically assigning them to either of the two 5GHz or one 2.4GHz bands based on their speed, distance from the router, and band loads.
RT-AC3200 delivers a combined data rate of 3200Mbit/s and is capable of handling smooth 4K/UHD video streaming, ultra-fast large file transfers and low-latency online gaming without slow-downs.
With six antennas, RT-AC3200 provides two 3×3 802.11ac bands and one 3×3 802.11n band for wide coverage and performance.
RT-AC3200 features AiProtection, with exclusive Trend Micro software, to protect home networks from cyber threats. It monitors the network in real-time, detecting malicious sites, malware, and other intrusions for total network security. It even includes robust parental controls and privacy protection.
ASUS RT-AC87U
ASUS RT-AC87U is a dual-band router with a combined data rate of 2334Mbit/s for smooth 4K/UHD video streaming, ultra-fast large file transfers and low-latency online gaming.  It has the world’s fastest 5GHz band, with a data rate of up to 1700Mbit/s. It has the world’s first 4×4 MIMO antenna design with AiRadar universal beamforming for superb multi-device performance and widespread wireless signal coverage of up to 465m2 (approximately 5,000ft2). Like the RT-AC3200, it also features AiProtection.
ASUS EA-AC87
ASUS EA-AC87 is the world’s fastest 4×4 Wi-Fi client with a data rate of 1734Mbit/s for smooth 4K/UHD video streaming and lag-free gaming on a PC, Xbox One, or PlayStation® 4. It has Access Point mode to add 5Ghz wireless access to an existing wired network, and Media Bridge mode adds wireless connectivity to wired network devices such as games consoles or TVs.
