The new low light champion action camera
The action camera world usually just gives us tiny upgrades—a little more resolution here, slightly better stabilization there. But seriously, the DJI Osmo Action 6 is different. This isn’t just an upgrade; it’s a massive leap forward that packs true creative power, like you’d find on a professional camera, into a rugged little package that can even enter water.
We’ve been goign around testing out this camera for almost a week, putting it through the outdoor under brigth sunlight and almost pitch dark environment. Finally, we conclude it is a killer night performance, including crystal-clear still photos and super slow motion capabilities.
The Heart of the Beast: The 1/1.1-inch Square Sensor
For years, the gold standard in action cameras hovered around the 1/1.3-inch sensor size. The Action 6 blows past that with a new, much larger 1/1.1-inch CMOS sensor. That size bump might sound nerdy, but it’s huge: it grabs way more light than previous models, which means cleaner images, richer colors, and up to 13.5 stops of dynamic range—great for both video and high-resolution still photos.
But the real magic isn’t just the size—it’s the square shape.
This square sensor design is an absolute godsend for modern content creators. It introduces a feature called “4K Free Cut,” meaning you can shoot once and then jump into the DJI Mimo app to choose your final screen ratio—whether you want it wide (16:9) for YouTube or vertical (9:16) for TikTok—all without losing resolution or flipping the camera in the field. If you’re constantly juggling formats, this feature is an efficiency superstar that saves you time and preserves quality.
Creative Control Arrives: The Variable Aperture (f/2.0 to f/4.0)
This is the feature that changes everything. The Osmo Action 6 is the first to introduce a mechanical variable aperture, ranging from f/2.0 to f/4.0.
Action cameras usually have a fixed lens at f/2.8. That’s fine, but in bright sunlight, you often need those fiddly ND filters. Not anymore! The Action 6 gives you two distinct shooting options:
- f/2.0 (Wide Open): This is your low-light and slow-motion superstar. It lets in tons of light, directly improving image quality in shaded areas or for capturing super smooth slow motion footage. It even allows for a tiny bit of separation between your subject and the background.
- f/4.0 (Stopped Down): Perfect for bright sunlight, stopping the aperture down helps manage overexposure, cutting down on the need for external ND filters. It also provides a greater depth of field, so more of your expansive scene stays sharp. Plus, you get the cool Starburst Mode at f/4.0, which turns night lights into crisp, professional-looking star patterns.
Conquering the Dark: Low-Light and Night Video Performance
The combo of that big 1/1.1-inch sensor and the wide f/2.0 aperture means the Action 6 is finally built to handle the night. Most action cams turn dark environments into noisy, muddy messes, but our testing in genuinely dark environments confirmed that this camera is different.
The Action 6’s SuperNight Mode, which can push ISO up to 51200, is absolutely phenomenal. It really makes a huge difference to the video quality—the footage is cleaner, noise is managed beautifully, and you retain surprising detail in shadows. Whether you’re capturing late-night city cycling, documenting astrophotography, or simply filming a dimly lit campfire, the low-light video quality here is finally competitive with much bigger cameras.
We have place more photos and videos in our video review on page 2 of this review
Unshakeable Focus: Stabilization Modes
DJI has always been great at stabilization, but the Osmo Action 6 refines its tech even further. It ensures your footage is completely smooth, no matter the chaos you throw at it.
The core systems are:
- RockSteady 3.0+: This is the standard Electronic Image Stabilization (EIS) that gives you that butter-smooth, gimbal-like look. It handles the high-frequency jitters from mountain biking or fast running perfectly.
- HorizonSteady: The real hero for extreme movement. This mode guarantees your horizon stays perfectly level, even if the camera itself flips or rotates a full 360 degrees. It’s perfect for action sports where the world is constantly turning, keeping the viewer grounded and the footage incredibly professional.
The robust stabilization paired with the improved dynamic range means you get professional-looking footage right out of the camera, minimizing the need for heavy post-production correction.
Read page 2 for our review review on youtube.
