ECS DURATHON Technology Introduction
Triple Density PCB — 3-Time More Effective Humidity Protection
ECS Durathon Technology adopts the highest level Bi-Directional Splitting Glass Fabric PCB
Many researches have pointed out that moisture is one of the key factors that would affect your PC longevity. To avoid short circuit, system instability, or even burn out malfunction caused by humid conditions, ECS Durathon Technology goes above and beyond industry standards and uses the highest quality components for PCB (Printed Circuit Board) to ensure that your motherboard can now deliver the stability, reliability and performance that we promise.
Damp Proof
ECS Durathon Technology certified Triple Density PCB adopts highest level Bi-Directional Splitting Glass Fabric, which is 3 times more effective humidity protection than general glass fabric and delivers a hassle free computing experience by solving common PC hardware problems before they can even occur.
Compare with other glass fabric, Bi-Directional Splitting Glass Fabric adopted by Durathon Triple Density PCB narrows the vacant space between the glass fabric of the PCB which can effectively lower air permeability for dampness proofing and reduce short circuit or burn out malfunction.
High Temperature Tolerance
Durathon Triple Density PCB also improves the thermal stress of the PCB and makes the motherboard more reliable against heat. ECS Bi-Directional Splitting Glass Fabric is the highest level splitting glass fabric with highest quality copper foil and resin.
Motherboard Quality You Can Trust
ECS Durathon comprises four interlocking tests and enhancements together to protect PCs and defeat all the vital causes of hardware problems and system instability, which includes Triple Density PCB, Extreme Temperature Resistance, 1.5K Marathon Testing, and Superior Solid Capacitors. When it comes to quality and durability of your motherboard, ECS goes above and beyond industry standards to ensure that you have a motherboard that will last long and continue to outperform the competition. Trust only motherboards built with Durathon Technology.
