The H67H2-M is a micro ATX board that supports the upcoming new Intel processor to be launched in January next year.
The ECS H67H2-M can support up to 4 display, supports HDMI for HD, Blu-ray stereoscopic 3D movies and gaming.
Based on the Intel H67 Express chipset, it supports dual channel DDR3 memory architecture of up to 16GB (4 DIMMS).
For expandability, it supports 1 PCIe Gen 2 slot, 2 PCIe x1 Gen 2 and 1 x PCI slot.
On board you can also find 2 SATA 6Gbps port, 3 SATA 3Gbps port and 1 eSATA 3.0 Gbps port for storage.
Dual GbE Lan, 2 x SB 3.0, 4 x USB 2.0, 1 HDMI, 2 RJ45, 1 Clear CMOS, 1 audio port, 1 DSUB, 1 DVI, 1 display port and 1 eSATA 3Gbps port can be found on the rear panel of the board.
The board uses 15u Gold contact for CPU socket PCIe slots offering 3 x extra anti-oxidation.
The software on board includes eOC, eGS, eSF, eBLU, eDLU and eJIFFY to ensure easy tweaking and updates.
Other features on board include M.I.B X which saves overclocking profiles. Qooltech III for silent operation. For iPhone and iPAD users, you can now fast charge it using the USB ports on board.
