ECS has been pretty busy with it’s upcoming boards. As you all know, new boards from other vendors are now adopting the Hydra technology so that you can use A/N/MIXed graphics cards from different vendors on the same board.
ECS’s joins MSI and ASUS to deliver the upcoming P67H2-A board with this capability. The ECS P67H2-A features the Socket LGA1155 for Sandy Bridge high end processors. Featuring the P67 chipset, it has a DMI running at 5.0GT/s.
Simiar to the P55, it has a a dual-channel DDR3 memory architecture with 4 x 240-pin DDR3 DIMM socket up to 16GB, It supports DDR3-1333 SDRAM with OC capability and supporst up to OC of 2600MHz.
On board are 3 x PCI Express x16 Gen2.0 slots , 2 x PCI Express x1 slots, 2 x PCI slots. As for storage, the board features 4 x SATAII 3.0Gb/s, 2 x SATAIII 6.0Gb/s and 2 x ESATAIII 6.0Gb/s ports.
Multimedia features include Realtek ALC892 8-CH High Definition audio CODEC (Compliant with HD audio specification). It also has Dual Realtek 8111E Gigabit Lan.
The rear I/O connectors include 4 x USB3.0 port(Compatible with 2 x USB2.0 ports) , 6 x USB2.0 ports ,
2 x RJ45 Lan connectors, 1x Audio port(1xLine in,4xLine out,1xOptical SPDIF Out), 1x PS/2 keyboard & PS/2 mouse connector, 1x CLR CMOS bottom.
