G.SKILL Releases Extreme Performance Phoenix Blade Series 480GB PCIe SSD
A Beast of Blazing Speed and Massive Capacity
Taipei, Taiwan – 22 October 2014 – G.SKILL International Co., Ltd., the leading high performance memory and SSD designer and manufacturer, is excited to announce the Phoenix Blade Series PCIe SSD, the next generation of high-speed, high-capacity storage device. The Phoenix Blade PCIe SSD is the perfect storage solution for extreme gaming, professional graphic design, industrial design, and HD video & audio content creation.
By introducing extreme read and write performance, the potential of today’s multi-core processors can be unleashed, resulting in higher productivity and performance, whether you are in extreme gaming or professional design.
x4 SSD Controllers in RAID0 Setup
Built with x4 LSI SF-2281 SSD controllers in a RAID0 setup and integrated with a massive 480GB array of MLC flash, G.SKILL Phoenix Blade PCIe SSD increases the bandwidth performance up to 4 times over typical SATA3 based SSDs!
PCIe Gen 2.0 x8 Interface
G.SKILL Phoenix Blade PCIe SSD is designed with a PCIe Gen 2.0 x8 high-speed interface, allowing the system to effortlessly send massive amounts of data to and from the SSD and drastically improves performance for professional and industrial graphic applications.
Up to 2,000MB/s Extreme Read and Write Performance
With 480 gigabytes of storage capacity, the G.SKILL Phoenix Blade PCIe SSD is pushing the maximum limit of read and write speeds at up to 2,000MB per second, so large data transfers are faster than ever!
Up to 245K IOPS 4KB Random Write
G.SKILL Phoenix Blade PCIe SSD delivers an incredibly fast 245K IOPS! Experience the performance boost in data intensive processing, such as professional graphic/industrial design and HD multimedia content creation software applications.
TRIM & SMART Support
TRIM and SCSI UNMAP support with major Windows OS versions help maintain consistent write performance, reduce flash deterioration, and most importantly, extend drive life expectancy. Not to mention an extensive set of S.M.A.R.T. attributes allow users to monitor the drive’s health, allowing users to take preventative measures against possible data loss.
Enhanced Data Protection
CRC data protection prevents data corruption during data transfers. By implementing BCH ECC of up to 55 bits per sector and RAID-5-like data protection, flash cell errors and page/block failures are yesterday’s news.
3-Year Limited Warranty
The G.SKILL Phoenix Blade PCIe SSD includes a 3-year limited warranty and full technical support from our tech support team.
