Cinebench 11.5 x64
In this rendering benchmark we test the CPU and OpenGL performance.
From the results, we can see that the board runs pretty fast scoring 6.34 against the others. With it overclocked to 4.4GHz and iGPU to 1.5GHz, the score went up to 7.3.
In OpenGL, the non OC result has a result of 22.36 fps which is 1 fps higher than the rest of the boards tested. When overclocked, it shot up to 27.06 fps which is higher than the ASRock 26.25.
