sdr
At the LG Home Entertainment & IT Media Launch 2018 held at the Marina Sands Expo & Convention Centre, LG showcase the latest Alpha 9 image processor with LG OLED W8 TV, 21:9 ultrawide monitors, gaming monitors with 240 Hz refresh rate and 15 inches LG Gram. The LG Gram was also the centre of attraction as it was demonstrated to withstand heavy weights (See video demo).
Impressive noise reduction is the new Alpha 9 processor found in the new LG OLED W8 TVs. Compared side by side, the Alpha 9 does a better job in the enhancement of the picture quality. It also shows more vibrant and natural colours, enhanced with Dolby Vision. For 360 degree cinematic sound, the OLED W8 also comes together with a soundbar equipped with Dolby Atmos.
LG SUPER UHD TV
LG’s SUPER UHD TVs have Nano Cell Display technology, and Full Array Local Dimming for rich, accurate colors and deepest blacks from every viewing angle. The Full Array Local Dimming basically allows the TV to have more control over darkness, so that it can produce pictures that have higher contrast, and appear more vibrant. Most LCD TVs are lit only from the sides, but full-array dimming means that there is a full panel of individual LEDs behind the LCD panel. This gives more precise control over which parts to dim for enhanced contrast, and a more intense picture.
21:9 Ultra Wide monitors
For office productivity or for the hardworking software programmers, the 21:9 UltraWide monitors might come useful. It offers a wider screen resolution compared to conventional screen for multitasking between coding and debugging on the same screen. It also comes with a Thunderbolt port renders the monitors Mac-compatible, and provides multiple functions – like charge, display, and transfer data.
Enjoy gamers without lag with LG’s gaming monitors come with G Sync and Free Sync technology for smooth gameplay with a refresh rate of 240 Hz. Together with 1ms motion blur reduction that produce clearer visuals, gamers are well-equipped with the gaming advantages to win.
LG Gram 15″
The new LG gram is the world’s lightest 15 inch laptop, and has a highly efficient battery, which lasts up to almost a full day on a single charge. Its Nano Carbon Magnesium full metal alloy body, often used in the aerospace industry, is built to withstand high strength while maintaining its incredible light weight.
At 970 grams, it is lightweight and can withstand a weight of 100x of it’s weight. This durability gives it the proven MIL-STD-810G stamp of approval. Below Is a video to demonstrate the durability of the LG Gram.
