Technical Specifications
Colour Black
Dimensions 139.5 × 69 × 7.3 mm
Weight 110 g
Operating system EXPECT 5.0 on Android 4.4.4 Kit Kat
Processor 1.5 GHz Qualcomm Snapdragon 615 Octa-Core (MSM8939)
RAM 2GB
Storage 16GB (expandable up to 64GB using microSD card)
Sensors Barometer
Proximity Sensor
Gesture Sensor
Pedometer Sensor
E-Compass
Gravity Sensor
Step-counter Sensor
Battery 2,300 mAh Li battery
Display and Graphics
Size 5.0”
Resolution Full HD (1920 x 1080 pixels), 441 PPI
Type IPS panel using 3rd Generation Corning Glass
Touchscreen Multi-touch capacitive screen, support for gloved and wet touch
input
GPU Qualcomm Adreno 405
API Support Direct X 9.3
OpenGL ES 3.0
H.264 Hardware Decoder
1x 800MHz LPDDR3
1080p Full HD @ 60 FPS (for Video decode)
Camera
Main Camera 13-megapixel with 1.12um pixel using Sony CMOS IMX214 sensor
Aperture f/2.0
Features 6x Digital Zoom
Autofocus
Tap to focus
Exposure control
Timer mode
Photo Geotagging
Multi Face Detection
Burst/Zero Shutter/Anti-shake mode
