How to setup and Conclusion
Contents
Setup
To setup the Pixels Bud Pro, you would need to remove the earbud from the holder and turn on bluetooth to pair it with the Pixel Bud Pro.
If you haven’t install PIxel Bud app, a prompt will ask you to install it via the google play store.
Follow through the instructions to install the app on your smartphone.
During the installation process, it will check your eartip seal to ensure maximum noise reduction.
Once that is done, you can configure which earbud to invoke Google Assistant or turn on/off active noise cancellation.
