Intro
Contents
Redmi has always deliver best cost/peformance products for the masses who is looking for great specs with affordable pricing.
As Flag ship phones usually have the highest end specifications featuring the processor and features, there is definitely for a mid ranger to fit the price conscious segment of the market.
The Redmi Note 11 Pro 5G is powered by the Snapdragon 695, although it is a 600 series processor, that doesn’t make it slow. Complementing the phone are 108MP camera, a 20Hz FHD+ AMOLED DotDisplay and 67W turbo charging and 5G SA/NSA.
Photography is one of the focus of the Redmi Note 11 Pro 5G. It has a 108MP wide camera f/1.90.7μm, 9-in-1 binning into one large 2.1μm pixel1/1.52” sensor size (larger sensor size captures more light at night), a 8MP ultra-wide camera f/2.2FOV 118° and a 2MP macro camera f/2.4. For Recording there is only 1080p support.
As for the front camera , there is a 16MP front camera f/2.4 with Front camera video recording at 1080p 1920×1080 | 30fps720p 1280×720 | 30fps
Compared to other models which uses LCD screen. AMOLED screen display is way clearer even with it’s smooth 120 Hz screen refresh rate.
The prebuilt 5000mAh battery is supported by a 67W turbo charging with the charger provided. it can charge up to 100% in 42 minutes.
As it is a 5G SA/NSA phone, it supports the bands n1/3/5/7/8/20/28/38/40/41/66/77/78. As most of the region supports the band n78 for SA (n1 for NSA), this phone should be compatible with most telcos in the region if they provision the 5G SA service.
It also has Bluetooth 5.1, NFC and WIFI 802.11a/b/g/n/ac for faster wifi speeds.
Processor Snapdragon® 695
CPU: Octa-core CPU, up to 2.2GHz
GPU: Qualcomm® Adreno™ 619
Storage and RAM6+64/6+128/8+128GB
LPDDR4X + UFS2.2Expandable storage up to 1TB*
Available storage and RAM are less than the total memory due to storage of the operating system and software pre-installed on the device.
Dimensions
Height: 164.19mmWidth: 76.1mmThickness: 8.12mmWeight: 202g
Display 6.67″ FHD+ AMOLED DotDisplayRefresh rate: Up to 120HzBrightness: HBM 700 nits (typ), 1200 nits peak brightness (typ)Contrast ratio: 4,500,000:1Resolution: 2400 x 1080DCI-P3 wide color gamut395 ppiSunlight displayReading mode 3.0
Rear camera
Rear camera video recording 1080p 1920×1080 | 30fps 720p 1280×720 | 30fps
Front camera
Front camera video recording 1080p 1920×1080 | 30fps720p 1280×720 | 30fps
Battery & Charging 5000mAh (typ)67W turbo charging67W in-box chargerUSB-C
Security Side fingerprint sensorAI Face Unlock
NFC Availability varies between market*Functions may vary in some markets.
Network & Connectivity SIM 1 + Hybrid (SIM or MicroSD)2G: GSM: 850 900 1800 1900MHz
3G: WCDMA:1/2/4/5/8/19
4G: LTE FDD:1/2/3/4/5/7/8/12/13/17/18/19/20/26/28/32/66
4G: LTE TDD:38/40/41
5G: n1/3/5/7/8/20/28/38/40/41/66/77/78
Bluetooth 5.1Wi-Fi Protocol: 802.11a/b/g/n/ac
Navigation & Positioning GPS L1 | Glonass G1 | BDS B1 | Galileo E1
Audio Dual speakers3.5mm headphone jackHi-Res Audio certification
Sensors Proximity sensor | Ambient light sensor | Accelerometer | Electronic compass | IR blaster |Gyroscope
Operating System MIUI 13, based on Android 11
Package Contents Redmi Note 11 Pro 5G / Adapter / USB Type-C Cable / SIM Eject Tool / Protective Case /Quick Start Guide / Warranty Card
