Overclocking and CPU-Z
Contents
Our test setup includes the Gigabyte B550 AORUS MASTER motherboard, ATC 700 cooler, AORUS RGB memory (2x8GB) and Radeon 5500XT graphics card.
Processor used is AMD Ryzen 3 3300X.
Windows 10 Ver 2004 build 19041.329
Radeon Driver 27.20.1017.1011
The system was tested running in default speed of 3.8 GHz (Ryzen 3 3300X) with XMP Profile #1 which sets the memory to run at CAS 16-18-18-1T.
Overclocking the AMD Ryzen 3 3300X is quite straightforward with our test system. The Vcore is increased on 1.35v, memory is fixed at XMP Profile #1 (C16-18-18-1T) The CPU multiplier is raised to 45X and lowered to 43X as we find that running benchmarks above 43X results in an unstable system.
