Futuremark 3DMarkVantage (P) and (E) tests
In 3DMark Vantage test, we can clearly see that the BIOSTAR TA75A+ is on par with the two other boards. It scored 16213 marks and 19203 in overclocked mode. It is quite a surprise that with the overclocked APU, the score is lower than the two others.
In performance mode, BIOSTAR TA75+ scored 4453 marks, highest among the three. Although we expect better results during overclocked mode, it turned out otherwise. I suspect it is because of the lower memory bandwidth used as it wasn’t able to run the supporting DDR3 video memory of up to 2100+ MHz. Nevertheless, it’s performance is still not that bad at 5257 marks.
