DRACO HDT2-7200 DVB-T2 Receiver Review
OCWorkbench 12 Jan 2014
DVB-T2 Receiver S$23.90 https://c.lazada.sg/t/c.YwIH5Z
Singapore’s free to air broadcaster MediaCorp started it’s transmission of the local TV channels digitally a fortnight ago. Although analog broadcasts are still available, you will not be able to tune in after analog signals are switched off in 2016 unless you install a set top box or subscribe to Singtel mio TV or Starhub TV.
In the past, only 4 channels were transmitted in DVB-T format, that is HD 5, 5 (SD) , 8 (SD) and ChannelNewsAsia (SD). Using the DRACO HDT2-7200 DVB-T2 receiver, we are able to receive more channels as the standard delivers more High Definition channels sharing the same frequency. Currently, MediaCorp is transmitting on channels 27, 29 and 31. Channel 27 delivers OKTO, CNA and Channel U all in SD. Channel 29 carries both Channel 5 and Suria in High Definition. Channel 31 carries both Channel 8 and Vasantham both in High Definition. There is another test channel on Channel 33 which is showing a test pattern and a looping scenery clip. Channel 38 is still transmitting 4 channels in DVB-T standard. The older IDTVs receivers will still be able to receive HD5 but Channel 8 will be in SD only.
We bought the set top box from a local retailer at SGD 129.00, unboxed it and set it up for a test.
Below is the unboxing video.
Currently there are sellers of DVB-T2 devices (non Draco brand) on Lazada.sg
No Brand DVB-T2 receiver at S$29 on Lazada https://c.lazada.sg/t/c.YwIH51
MediaCorp will be turning off the TV signals in 2017. If you haven’t , it is time to switch to digital.
If you own the vodoke playstaq, this device can also be used to receive dvb-t2 broadcasts
http://forums.ocworkbench.com/showthread.php?p=706544#post706544
Check out this Amazon deal: Mohu Leaf 50 Amplified Indoor HDTV Antenna by Mohu http://amzn.to/1Pg3sBj via @amazon
50-mile range to access Over-the-Air TV channels without a cable or satellite subscription (NOTE: Enables access to free channels only – does not enable access to paid channels such as ESPN/Fox News)
CleanPeak Filter technology filters out cellular and FM signals, resulting in a clearer picture and allowing access to more channels
Multi-directional and Reversible: No “pointing” needed and comes with included 16 ft. high performance cable
DISCLAIMER: Channel reception varies based on what is broadcast in your area, your distance from broadcast towers, and any geographical obstructions between you and the towers. Before you buy, visit http://dtv.gov/maps to see what channels are available in your area
Comes with 1 Year warranty. Email us at support@gomohu.com for help setting up your product. You can also visit http://www.gomohu.com or call 1-855-4GOMOHU (855-446-6648).
50-mile range to access Over-the-Air TV channels without a cable or satellite subscription. Modeled after a discrete mud flap antenna designed for the U.S. Military
Reversible and paintable to match décor and CleanPeak Filter technology filters out cellular and FM signals, resulting in a clearer picture and allowing access to more channels.
16 ft high performance cable included with 1 year part and labor warranty
our vessel came with Darco Satellite Tv reciever HD6300. it is not showing. is it because of my location Nigeria?
what do i do.thanks
Currently I rely on outdoor antenna with booster to my existing digital TV (not T2 ready). Can I just install HDT2-7300 and connect to the TV via HDMI port? Is this the best alternative?
No matter what for display you have to connect the debt tuner to the to via hdmi
Hi, do you think the antenna amplifier provided can pick up the Malaysian digital channels? I check Wikipedia and the launch date for the Malaysian digital tv is Apr 2015.
Anyone from JB can pick up SG digital channels?
Thanks
are there dvb t2 broadcasts from Johor?
There are some other models available in Singapore. You can check them out on page 3 of the review (Revised).
You are welcomed.
Hi! I have a miotv, but I record shows on the local channels using a DVD recorder. Am I able to use a DVB-T2 receive STB at the same time? So that I can record in HD and it does not affect the miotv or whatsoever.
mio tv and dvb-t2 tuners are two different tuners. They shouldn’t affect each other.
The Draco box already comes with a USB port which you can insert a USB stick and record the tv shows.
Hey! Thanks for your reply! 🙂 So, can I still connect to my DVD-R to record tv shows after getting HD channels from the receiver?
Why would you want to do that? The only available ports are RCA from the back panel , you will be recording in non HD resolution.
Unless your DVD recorder can accept HDMI in and record in Huigh Definition that is a different story.
So that I can burn into discs directly? I only see a HDMI AV out at the back of my DVD-R. Sorry, am really bad at this.
well you can but it won’t be in HD .
The best is to record it to the USB stick and use a computer to burn the contents into a DVD for archival purposes. Note the files are rather big.
Have you like our FANPage at http://www.fb.com/ocworkbenchconnect
and join our forums at http://forums.ocworkbench.com
do you have a picture of it?
This box can use in johor,malaysia?can see mediacorp all channel?
Yes it is reported that it works in coastal areas of JB.
Overall its a good device and pretty good review of it. Fantastic HD receiving potential this satellite receiver has. It is packed with all the necessary features and applications.
Hi, Just got one but having trouble getting the Free to air channels and any slight adjustment to the setup will render signal being lost totally. Any suggestion/recommendation on getting better reception and antenna placement?
Did you install the amplifier ? Try to place the circular Draco antenna near the window.
Hi! Just to check, does this set-top box supports dual sound?
Yes it can.
Yes it does.
