Installing the KOBOT RV337 is a breeze. Upon opening the package, you will see the various components including the Charging Home Base, Mop Attachment, Sweeping Brush, Battery etc. You will need to install them according to the operation manual provided.
Top view of the V337
The bottom of the RV337 reveals the battery compartment where you place the rechargeable battery. At the centre is the suction hole. Next to it’s left and right is two attachments for hooking up the sweeping brush
This is the home base which you need to mount it on the wall so that the RV337 is able to “stick” to it for a recharge
