Intro
Mediatek has been making in roads in the entry level 5G market. Today, we will review yet another Dimensity 700 based smartphone the Vivo y72 5G.
The Vivo Y72 5G is a dual SIM 5G standby 5G capable smartphone. Measuring 163.95mm x75.30mm x 8.50mm, it is quite a slim smartphone which comes with a 5000mAh battery. It is equipped with a LCD IPS 6.58inch 2408×1080 FHD+ screen. 18W fast charging is supported and you can fully charge up in an hour’s time.
In terms of memory, it has 8 GB RAM and 128 GB Storage. That is ample storage for your apps and photos.
Camera wise, it has a a front 16 MP at f/2.0, back are 64 MP at f/1.79, 8 MP at f/2.2 and a 2 MP at f/2.4. The camera software has some interesting features like Repair (old photos), light effect, Object erase, AI image matting which can replace the sky etc.
Connectivity wise, it has WIFI 2.4/5GHz, BT 5.1 USB C, NFC GPS, FM, OTG
The phone supports both SA and NSA but it really depends on whether the 5G is provisioned to work.
5G NR NSAn1/n3/n7/n8/n28/n40/n41/n78
5G NR SA*n1/n3/n28/n78/n40/n41
*SA capabilities depend on the network layout of local carrier. and it will be pushed through OTA upgrade after its official opening.
