Installation
For the Vodoke PlayStaq, there are no drivers required. Just insert it into any of the USB port and activate the LIVE TV app app and start watching. As for the PC, you would need to go to Vodoke website to download the drivers and install it accordingly.
At the end of the USB stick is the RF connector which you plug in your antenna. Do take note that there is no booster built in. You might need to get a good antenna to boost up the signal if you are using it indoors.
Here is a demonstration of the app being used to tune in to local broadcasts.
