Lately, we see various motherboard manufacturers posted memory records one after another. It started from DDR3-2600 and all the way to DDR3-3733.
According to the email, it is said that the result showing DDR3-3733 is bogus. The tester uses a CPU-Z bug to achieve this high ram speed.
According to the email, this result can be duplicated by doing the following :
Use CPU-Z version 1.592, tune the RAM to DDR3-2600. It will be shown as DDR3-3466.
If you use the newer version, it will still be DDR3-2600.
Try it and let us know if you can duplicate it.
