It appears that SIMBA has once again raised the bar with its SIM ONLY Plan. It seems they’ve consolidated the previous SIM ONLY 100GB+ plan and SIM ONLY 130GB ($18) plan into the new SIM ONLY 200GB offering. The price has also been adjusted from $10.50 and $18 to $12 per 30 days. Additionally, both the SIM ONLY 130GB ($18) plan and the SIM ONLY 100GB+ plan seem to have been removed from the available options.
This new plan has more to offer. For the first 6 x 30 days (6 cycles) you will get 200 GB per 30 days. After which, it will be 130 GB per 30 days on the 7th cycle. It comes with 50 local SMS.
It will come with 2 GB data roaming to 60 destinations and 300 IDD minutes to 21 destinations, 50 SMS. The old SIM ONLY 100GB+ only come with with 1 GB Roaming and 100 IDD minutes, 30 local SMS.
You can upgrade or downgrade your current plan. See chart below.
