SIMBA is now offering the eero Max 7 WIFI 7 router at COMEX held at SUNTEC Convention Centre. A single node is at S$399. #simbabroadband.
Experience wired network speeds up to 9.4 Gbps and wireless network speeds up to 4.3 Gbps
eero’s first device with Wi-Fi 7 technology can provide more than twice the speed of Wi-Fi 6
Supports 200+ connected devices and provides up to 7,500 sq. ft. of coverage.
Wifi connectivity
Wi-Fi 7 Tri-band concurrent 2:4:4 (802.11a/b/g/n/ac/ax/be) with support for 240 MHz channels in 5 GHz and 320 MHz channels in 6 GHz; compatible with older Wi-Fi standards
Requirements
Operating: 32°F to 104°F (0°C to 40°C); Electrical: 100-240V AC, 50/60 Hz; Power supply: 45W external USB-PD
Processor, memory, and storage
Quad-core A73 processor, 2GB RAM, 4GB flash storage
Dimensions
7.24 x 8.73 x 3.54in (183.90 x 221.89 x 89.90mm) Actual size may vary by manufacturing process.
Wired connectivity
Two auto-sensing 10 GbE ports and two auto-sensing 2.5 GbE ports
Required for setup
Internet connection, modem, Ethernet cable, and smartphone. See eero.com/requirements
Security and network services
Profiles, WPA3 (eero Labs feature), WPA2, TLS v1.2+, VPN passthrough, IPv6, NAT, UPnP, port forwarding, DHCP, static IP, and cloud connectivity
Warranty and Support
1-year limited warranty. Customer support is available 7 days a week. Learn more about our warranty and support.
Smart home connectivity
Works with Alexa, Smart Home Hub, Thread devices and Matter and Zigbee devices (as a controller only), Bluetooth Low Energy 5.0, Works with Alexa
