Specifications
Specifications Sheet
Model Name |
α7 II (ILCE-7M2) |
Lens mount |
E-mount |
Image sensor |
Image sensor |
35mm full frame (35.8 x 23.9mm), Exmor CMOS sensor |
Number of pixels (effective) |
Approx. 24.3 megapixels |
Lens mount |
E mount |
Recording format |
Still images |
JPEG (DCF Ver. 2.0, Exif Ver. 2.3, MPF baseline compliant), RAW (Sony ARW 2.3 format) |
Movies |
XAVC S / AVCHD format Ver. 2.0 compliant / MP4 |
Movie functions |
Picture Profile |
Picture Profile (Off/1-7, Black Level, Gamma (Movie, Still, Cine1-4, ITU709, ITU709 [800%], S-Log2), Black Gamma, Knee, Color Mode, Saturation, Color Phase, Color Depth, Detail, Copy, Reset) |
Other |
Time Code/User Bit, Rec Control, Auto Slow Shutter, Dual Video Rec, Marker Setting |
Clean HDMI output |
1920 x 1080 (60p (50p) / 60i (50i) / 24p) |
YCbCr 4:2:2 8bit/RGB 8bit |
Media |
Memory Stick PRO Duo, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo, SD memory card, SDHC memory card (UHS-I compliant), SDXC memory card (UHS-I compliant) |
Focus system |
Type |
Fast Hybrid AF (phase-detection AF/contrast-detection AF) |
Focus point |
Full frame: 117 points (phase-detection AF) / APS-C: 99 points (phase-detection AF) /25 points (contrast-detection AF) |
Sensitivity range |
EV -1 to EV 20 (at ISO 100 equivalent with F2.0 lens attached) |
Exposure control |
Metering type |
1200 zone-evaluative metering |
ISO sensitivity (Recommended Exposure Index) |
Still images: ISO 100-25600 (ISO 50/64/80 expandable), AUTO (ISO 100-6400, selectable lower limit and upper limit), Multi Frame NR (expandable up to ISO 51200) |
Movies: ISO 200-25600 equivalent, AUTO (ISO 200-6400) |
Shutter |
Shutter speed |
Still images: 1//8000 to 30 sec., Bulb |
Movies: 1/8000 to 1/4 sec. |
Electronic front curtain shutter |
Yes (On / Off) |
SteadyShot INSIDE (image stabilisation) |
Image Sensor-Shift mechanism with 5-axis compensation (Compensation depends on lens specifications) |
4.5 steps (Based on CIPA standard. Pitch/yaw shake only. With Sonnar T* FE 55mm F1.8 ZA lens mounted. Long exposure NR off.) |
Drive |
Continuous shooting speed*1 |
Hi: Max. approx. 5fps, Low: Max. approx. 2.5fps |
No. of recordable frames (approx.) during continuous shooting*1 |
Continuous shooting Hi: 77 frames/25 frames (RAW) |
Viewfinder |
Type |
Electronic viewfinder (XGA OLED Tru-Finder) |
Total number of dots |
2,359,296 dots |
Field coverage |
100% |
Magnification |
Approx. 0.71x (with 50mm lens at infinity, -1m-1 diopter) |
LCD screen |
Type |
7.5cm (3.0 type) TFT drive |
1,228,800 dots |
Adjustable angle |
Up approx. 107 degrees, down approx. 41 degrees |
Audio |
Microphone |
Built-in stereo microphone |
Speaker |
Built-in, monaural |
Interface |
Multi interface shoe, HDMI micro connector (Type-D), Microphone terminal (3.5mm Stereo minijack), Headphone terminal (3.5mm Stereo minijack), Multi / Micro USB Terminal |
Wireless LAN (built-in) |
Wi-Fi Compatible, IEEE802.11b/g/n (2.4GHz band) |
NFC |
NFC Forum Type 3 Tag compatible |
PlayMemories Camera Apps |
Yes |
Battery |
Rechargeable battery pack NP-FW50 |
Weight |
Approx. 599g (with battery and Memory Stick PRO Duo) |
Approx. 566g (body only) |
Dimensions |
Approx. 126.9 x 95.7 x 59.7mm (W x H x D, CIPA compliant) |
Operating temperature |
0-40°C |
