If 50 GB a mth is not enough for you, the new TPG 80 GB SIM plan may be the right fit.
At S$18/mth, the 80 GB SIM ONLY plan is similar to it’s 50 GB plan. Other than the increase in data bundle, it now provides 2 GB Data Roaming in selected countries. There will also be free incoming calls, free caller ID, 500 mins or local outgoing calls and 50 local SMS bundled in the plan.
Free 300 IDD minutes to selected countries.
