Package & Specifications
Contents
In the package, it consists of
Headset
Documentation
Type-C to USB Cable
USB Power Adapter
Type-C to 3.5mm Earphone Jack Adapter
Eject Tool
Phone Case
Protective Film (applied)
- Basic
- Processor MediaTek Dimensity 1300
- RAM&ROM12GB+256GB
*Actual available RAM is less than 12GB due to the storage of the operating system and pre-installed apps.
*Actual available ROM is less than 256GB due to the storage of the operating system and pre-installed apps.More - Battery4830mAh (typical value)
4730mAh (rated value) - Fast Charging66W (11V/6A)
*V25 Pro is equipped with vivo standard charger , and supports up to 66W. The actual charging power is dynamically adjusted as the scene changes, and subject to actual use.More - ColorStarlight Black, Surfing Blue
- Operating SystemFuntouch OS 12
- Display
- Screen6.56-inch
*Measured diagonally, the screen size is 6.56-inch in the full rectangle. Actual display area is slightly smaller. - Resolution2376×1080 (FHD+)
- TypeAMOLED
- Touch ScreenCapacitive multi-touch
- Screen6.56-inch
- Digital Cameras
- CameraFront 32MP AF / Rear 64MP OIS + 8MP wide-angle + 2MP macro
- ApertureFront: main f/2.45
Rear: main f/1.89 wide-angle f/2.2 macro f/2.4 - FlashRear flash
- Scene ModesFront: Photo, Night, Video, Live Photo, AR Stickers, Fun Video/Vlog Movie, Portrait, Double Exposure, Pro Sports, Dual View
Rear: Photo, Night, Video, High Resolution, Panorama, Slow Motion, Live Photo, Time-Lapse, Pro, AR Stickers, Documents, Dual View, Fun Video/Vlog Movie, Portrait, Double Exposure, Pro SportsMore
- Connectivity
- Wi-Fi2.4GHz, 5GHz
- BluetoothBluetooth 5.2
- USBType-C
- GPSSupported
- NFCSupported
- OTGSupported
- Network
- SIM Slot Type2 nano SIMs
- Standby ModeDual SIM Dual Standby (DSDS)
- 2G GSMGSM850/900/1800/1900MHz
- 3G WCDMAB1/2/4/5/8
- 4G FDD-LTEB1/2/3/4/5/7/8/12/13/17/18/19/20/26/28/66
- 4G TDD-LTEB38/39/40/41
- 5G NR NSAn1/3/5/7/8/28/38/40/41/77/78
- 5G NR SA*n1/2/3/5/7/8/20/28/40/41/66/77/78
5G band support depends on the available network and software version. The actual network frequency band usage depends on the deployment of local ISP.More
- Sensors
- FingerprintSupported
- AccelerometerSupported
- Ambient light sensorSupported
- Proximity SensorSupported
- E-compassSupported
- GyroscopeSupported
- Media
- Audio PlaybackWAV, MP3, MP2, MP1, MIDI, Vorbis, APE, FLAC, AAC, OPUS
- Video recordingMP4
- Voice RecordingSupported
- Location
- GPS, BEIDOU, GLONASS, GALILEO, QZSS
- In the box
- V25 Pro
Headset
Documentation
Type-C to USB Cable
USB Power Adapter
Eject Tool
Phone Case
- V25 Pro
