Features of the My Net N900 Central 2TB
Did we mention data backup? Yes, With WD Smartware utility, you can basically set it to backup your different PCs or notebooks data to a central location wirelessly through the dual band 2.4GHz and 5GHz bands router.
Below is a picture of the interface of WD SmartWare.
In addition to backup, you can create your on cloud storage. With the WD 2go file viewer, you can access your files, music and photos with smartphones and tablets with ease. You can also share your storage using DLNA, iTunes or set up a FTP server on it. You can also enable AFP server for sharing files using Mac OS X.
For streaming, the exclusive FasTrack Plus technology, it delivers smooth high-quality HD streaming to all your connected devices. Smart, real-time prioritization means your entertainment comes first.
Configuration is made simple by the entering 192.168.1.1 and you have access to the options available in the DashBoard.
With the DashBoard, you can setup the WiFi Network name, Guest Network Name, Internet security and Parental Control, attached storage, WD 2go Remote access etc.
Under security, you can enable the IPV4 SPI Firewall, set your DMZ IP, Mac Filter and parental controls.
