Telcos are now offering more and more data for it’s value plans. In fact, it is so common that it is offering it for roaming in neighbouring countries.
If you’ve ever been happily scrolling or streaming on your phone, locally or abroad, you will be happy to find that the speeds are pretty fast with low ping time. After probably hitting a certain amount, it starts to slow down.
What Exactly Is a Speed Cap or throttling ?
The probably reason is that you used too much data for the day. Most mobile carriers quietly put a limit on how fast your internet can go — even if you’re paying for an “unlimited” plan.
They come in different flavours, some will outright indicate that you will enjoy full speed for the first 50GB of the cycle/month and after which it will slow down to 512 kbps. This is very common among telcos
You’ll see this most often with:
  • Fair Usage Policies (FUP)
  • Travel eSIMs and international roaming
  • Budget or mid-tier unlimited plans
Is This Normal? Yes, Very Normal.
This isn’t just happening in one country — it’s pretty much standard practice globally:
  • United States: All major carriers (T-Mobile, Verizon, AT&T) throttle “unlimited” plans after you hit certain data thresholds.
  • UK & Europe: Many operators now have hard speed limits (like 100 Mbps max on new plans) and strict fair usage rules.
  • Asia, Australia, and beyond: Same story. Especially common with local unlimited plans and pretty much every travel eSIM out there.
Travel eSIMs are the worst offenders — a lot of them give you only 1–3 GB of full-speed data per day before slowing you down.
Why Do Carriers Do Cap your speed?
Actually it is very simple, mobile networks have limited capacity. Imagine if a small group of heavy users keep streaming 4K videos, downloads, hotspot, it will slow down the network for everyone that connects to the same base stastion. Throttling is the easiest and cheapest way for carriers to keep things running smoothly without building more towers every year.
Pay more for higher end plans with no throttling ?
Before you subscribe to any plan, ensure that you are comfortable with throttling. It is important to always read the fine print before buying a plan or eSIM.
Premium/expensive plans usually offer much better treatment (or sometimes truly unlimited high speed
Unfortunately for roaming, it is usually throttled as it is expensive to give users high speed 4/5G access that is as fast as the local sim for a fraction of the price.
“Unlimited” almost never means unlimited full-speed forever. Speed caps have become a normal part of mobile internet life in 2026, whether you’re on 4G or 5G. It is more of a marketing than really providing one with speedy downloads.
