Performance of Dimensity 9300+
The Snapdragon 8 Gen 3 generally holds a slight advantage in overall performance, especially in single-core tasks and sustained heavy workloads. It boasts a more balanced CPU architecture and a slightly more powerful GPU, leading to better performance in gaming and other graphically demanding applications. However, the Dimensity 9300+ excels in multi-core performance due to its unique all-big-core configuration, potentially offering superior performance in certain multi-threaded tasks. Both chipsets deliver flagship-level performance and handle everyday tasks with ease, so the choice might depend on specific usage patterns and priorities. If gaming and sustained peak performance are key factors, the Snapdragon 8 Gen 3 might be the better choice, while the Dimensity 9300+ could appeal to those prioritizing multi-tasking and efficiency.
Here are some screen shot of it’s performance using Geekbench for reference.
OpenCL Score
Vulkan Score
WIFI 7 performance
With more affordable WIFI 7 routers and broadband plans ranging from 2.5 to 10 Gbps, more users are looking for phones that support the higher WIFI spec. With the xiaomi phone, you can now download much faster before.
Using our 2.5 Gbps fibre broadband, we are getting close to our line speed (direct connection of PC to router gets 2.2 Gbps) of 2.07 Gbps. Below is a screen shot.
Test is done with MLO turned off and run ~1 metre away from the router.
