LIVE event
Xiaomi just launched the Redmi Note 9T based on the Mediatek Dimensity 800U Dual 5G smartphone. Priced from 229 Euros, it is possibly the cheapest smartphone you can find in the market right now.
You also get NFC, IR Blaster, 5000 mAH battery, 48 MP camera with a 8 MP wide and 2 MP macro at the rear.
The Redmi Note 9T is based on the MediaTek Dimensity 800U 5G (7 nm). Octa-core (2×2.4 GHz Cortex-A76 & 6×2.0 GHz Cortex-A55) GPU Mali-G57 MC3. It supports Dual 5G SIM.
MAIN CAMERA Triple 48 MP, f/1.8, 26mm (wide), 1/2.0″, 0.8µm, PDAF
8 MP, f/2.2, 118˚ (ultrawide), 1/4.0″, 1.12µm
2 MP, f/2.4, (macro)
Features LED flash, HDR, panorama
Video 4K@30fps, 1080p@30/60fps
SELFIE CAMERA Single 13 MP, f/2.3, 29mm (standard), 1/3.1″, 1.12µm
Video 1080p@30fps
BODY Dimensions 162 x 77.3 x 9.2 mm (6.38 x 3.04 x 0.36 in)
Weight 199 g (7.02 oz)
Build Glass front (Gorilla Glass 5), plastic back
SIM Dual SIM (Nano-SIM, dual stand-by)
Water-repellent coating
DISPLAY Type IPS LCD, 90Hz, 450 nits (typ)
Size 6.53 inches, 104.7 cm2 (~83.6% screen-to-body ratio)
Resolution 1080 x 2340 pixels, 19.5:9 ratio (~395 ppi density)
Protection Corning Gorilla Glass 5
