ZTE has launched a new budget-friendly gaming phone, the nubia Neo 5G. It features a 6.6-inch IPS LCD display with a 120Hz refresh rate, a Unisoc Tiger T820 chipset, 8GB of RAM, 256GB of storage, and a 4,500mAh battery with 22.5W fast charging.
The nubia Neo 5G also has a decent camera setup, with a 50MP primary sensor on the back and an 8MP sensor on the front. The phone can record videos at up to 1080p resolution.
Design and display
The nubia Neo 5G has a simple but sleek design. The phone has a plastic back and frame, but it doesn’t feel cheap or flimsy. The phone is also relatively lightweight and easy to hold.
The nubia Neo 5G has a 6.6-inch IPS LCD display with a 120Hz refresh rate. The display is sharp and clear, and the 120Hz refresh rate makes everything look and feel smooth and fluid.
Performance
The nubia Neo 5G is powered by a Unisoc Tiger T820 chipset, which is a mid-range chipset. The phone has 8GB of RAM and 256GB of storage.
The Unisoc Tiger T820 is slightly slower than the MediaTek Dimensity 810 in terms of overall performance.
Geekbench 5 (single-core) | 499 | 525 |
Geekbench 5 (multi-core) | 1656 | 1771 |
The nubia Neo 5G is not the most powerful phone on the market, but it’s still capable of handling most tasks without any problems. The phone can run games like PUBG Mobile and Call of Duty Mobile at medium to high settings.
Camera
The nubia Neo 5G has a decent camera setup, with a 50MP primary sensor on the back and an 8MP sensor on the front. The phone can record videos at up to 1080p resolution.
The 50MP primary sensor takes good photos in good lighting conditions. The photos are sharp and detailed, and the colors are accurate. However, the phone struggles in low light conditions, and the photos are often noisy and lack detail.
The 8MP front-facing camera takes decent selfies. The photos are sharp and detailed, but the colors are sometimes oversaturated.
Battery life
The nubia Neo 5G has a 4,500mAh battery with 22.5W fast charging. The phone can easily last a day on a single charge with moderate usage. However, if you’re a heavy user, you may need to charge the phone twice a day.
5G NSA and VoLTE support
The nubia Neo 5G supports SIMBA 5G NSA and VoLTE. This means that you can enjoy faster mobile data speeds and better call quality on compatible networks.
It is priced at SGD 299 and is available at the links below :
The nubia Neo 5G is a good budget-friendly gaming phone with a 120Hz display. The phone has decent performance, a decent camera setup, good battery life, and support for SIMBA 5G NSA and VoLTE.
If you’re looking for a budget-friendly gaming phone with a high refresh rate display and support for 5G NSA and VoLTE, the nubia Neo 5G is a good option to consider.
