Intel will be launching it’s Intel X99 chipset with Haswell-E processors soon. This new platform uses a newer DDR standard DDR4 memory. It looks like ADATA is ready.
ADATA Technology, a leading manufacturer of high-performance DRAM modules and NAND Flash application products, today launches the Premier DDR4 2133 Unbuffered DIMM memory, which supports the latest Intel Haswell-E platform for extreme performance. Thanks to the benefits of DDR4 and rigorous production of ADATA, the DDR4 2133 U-DIMM memory module is the best upgrade solution for PC DIY users.
Faster Data Transfer, Higher Power Efficiency
With speeds of up to 2133 MHz and a transfer bandwidth reaching 17 GB/s, the Premier DDR4 2133 Unbuffered DIMM provides greater efficiency of data transfer than previous generations of DRAM. Compared to DDR3, DDR4 memory features faster clock frequencies and lower power consumption. Running at just 1.2 volts, the new DDR4 2133 Unbuffered DIMM can save 20% of the power making it an environmentally friendly component. In desktop PCs, the advantages of DDR4 will lead to lower costs and improved overall performance.
