As usual, pictures first
The great mobo itself!
Sata ports. A total of 10! 6 by Z170 chipset, 4 by ASMedia ASM1061.
3 m.2 slots supporting NVME SSD boot. Do note that if you populate all 3 m.2 slots, the 6 sata port from the Z170 chipset will be disabled. There is also a mPCIE slot too.
2 Bios chip. Version p1.20, however on first boot. The bios version is P1.60 but a check on the website already show P3.00 available. Flash to the latest immediately
Purity Sound 3.
– 7.1 CH HD Audio with Content Protection (Realtek ALC1150 Audio Codec)
– Premium Blu-ray Audio support
– Supports Surge Protection (ASRock Full Spike Protection)
– Supports Purity Sound™ 3
– Nichicon Fine Gold Series Audio Caps
– 115dB SNR DAC with differential amplifier
– TI® NE5532 Premium Headset Amplifier (Supports up to 600 ohm headsets)
– Pure Power-In
– Direct Drive Technology
– PCB isolate shielding
– Supports DTS Connect
Infused natural oils are protected to make usee of
internally or externally; essential oils are
toxic intdrnally and problematic externally.
It’s typically considered protected to use tonifying herbs in water baases iif you aare
taking prescribed drugs.
Great post,Thank you for sharing this information!!
