Set Up
You do not need to have DIY knowledge to set up the monitor. In the package, there is a USB cable provided. Simply plug one end to the monitor and the other end to your notebook. Insert the CD-ROM and install the EZ-Link utility software. Once that is done, the system will detect the external screen. With the software installed, there will be an icon on the right hand corner of the task bar. Click on it and you will see the options on how you want it to be configured? For example, as a mirror screen to your notebook screen, an extension of the screen or make it the main screen (and your notebook becomes the secondary).
Price (UK) : £178.95
Price (US) : $294
