The package
RT-AC66U
The package box has some description of features of the router. It promises a speed of 3X faster than 802.11n, supports Cloud storage. The picture also depicts the multi functional 2 USB ports for connectivity to printers, 3G/4G dongles. There are 3 antennas and 4 GbE switch ports.
USB-AC53
Although you can use any compatible 802.11n USB dongles or the 802.11n wireless chip in your notebook to connect to the router, the USB-AC53 is the only 802.11ac compliant USB stick that can deliver up to 800Mbps compared to 300/450Mhz on 802.11n sticks.
ASUS also provides a Netclip so that it can be clipped onto the side of the monitor.
Network Standard | EEE 802.11ac (5GHz): up to 867Mbps*/ 802.11n (2.4GHz): up to 300Mbps | ||
Antenna | PIFA internal antenna x2 | ||
Host Interface | USB 2.0 | ||
Encryption | Supports 64/128-bit WEP, WPA, WPA2, TKIP, AES, WPA/ WPA2-PSK | ||
OS Support | Windows® 8 , 32bit/64bit Windows® 7 , 32bit/64bit Windows® Vista , 32bit/64bit Windows® XP , 32bit/64bit | ||
Extension Design | V | ||
WPS button | V | ||
Dimension | 96 x 26 x 12.45 mm |
Oh my goodness! Incredible article dude! Thanks, However I am
experiencing problems with your RSS. I don’t understand the
reason why I am unable to join it. Is there anybody getting identical RSS problems?
Anyone that knows the answer will you kindly respond?
Thanks!!
Attractive section of content. I just stumbled upon your website
and in accession capital to assert that I get in fact enjoyed account your blog posts.
Anyway I will be subscribing to your augment and even I achievement you
access consistently rapidly.
