ASUS Unveils the GeForce® GTX 650 Ti BOOST DirectCU II
Overclocked 1085MHz GPU, cool and stable performance plus GPU Tweak offer gamers a new sweet spot graphics card
Singapore (26 March, 2013) — ASUS today announced the GeForce® GTX 650 Ti  BOOST DirectCU II, which features an overclocked 1085MHz NVIDIA® GTX 650 Ti GPU paired with 2GB GDDR5 on a 192-bit interface. The card offers a combination of DirectX® 11.1-compatible power and  value, expanding the range of ASUS graphics cards that cater to gamers and DIY enthusiasts.
ASUS-exclusive features improve GeForce® GTX 650 Ti BOOST DirectCU II performance. They include the DirectCU II cooler, which maintains 20%* lower temperatures than a reference GTX 650 Ti BOOST, long-lasting Super Alloy Power components, and user-friendly GPU Tweak graphics card tuning.
PR ASUS GeForce GTX 650 Ti BOOST DirectCU II OC Edition with box
DirectCU II keeps high speed performance quieter and cooler
ASUS thermal design supports high end gaming with the stability of innovative cooling. Using all-copper heatpipes that directly touch the GTX 650 Ti GPU, DirectCU II expedites heat removal for 20%* lower temperatures than those of a comparable reference graphics card. A specially-selected 80mm fan with blades engineered to minimize drag is precision-fitted to the DirectCU II cooler, resulting in minimal vibration and noise. Compared to reference, the ASUS GeForce® GTX 650 Ti BOOST DirectCU II is up to three times quieter*.
Super Alloy Power components maintain stability and increase overclocking headroom
ASUS uses proprietary power delivery parts that can handle the heat and stress of gaming and overclocking over longer product lifespans. Solid state capacitors, concrete-core chokes, and hardened MOSFETs apply exclusive materials, leading to 1.5 times the longevity of reference cards and an average overclocking range increase of 15%.
GPU Tweak gives gamers easy access to graphics card tuning
Exclusive to ASUS graphics cards, the GPU Tweak utility offers a user-friendly interface that opens up versatile adjustments of graphics properties. Core and clock speeds, voltages, and fan speeds can be changed instantly, and multiple game-specific profiles may be created to make the most of each title.
NOTES TO EDITORS
30-word summary
The ASUS GeForce® GTX 650 Ti BOOST DirectCU II graphics card features an overclocked 1085MHz GPU, offering sweet spot graphics power and value. ASUS-exclusive features include the DirectCU II cooler, Super Alloy Power components, and GPU Tweak.
60-word summary
The ASUS GeForce® GTX 650 Ti BOOST DirectCU II graphics card features an overclocked 1085MHz GPU with 2GB GDDR5. It offers a combination of DirectX® 11.1-compatible power and value, expanding the sweet spot range of ASUS graphics cards. ASUS-exclusive features include the DirectCU II cooler for 20%* lower temperatures than reference, long-lasting Super Alloy Power components, and GPU Tweak graphics card tuning.
100-word summary
The ASUS GeForce® GTX 650 Ti BOOST DirectCU II graphics card features an overclocked 1085MHz NVIDIA® GTX 650 Ti GPU, paired with 2GB GDDR5 on a 192-bit interface. It offers a combination of DirectX® 11.1-compatible power and value, expanding the sweet spot range of ASUS graphics cards that cater to gamers and DIY enthusiasts. ASUS-exclusive features that add performance and value to the GeForce® GTX 650 Ti BOOST DirectCU II include the DirectCU II cooler, which maintains 20%* lower temperatures than a reference GTX 650 Ti Boost, long-lasting Super Alloy Power components, and the GPU Tweak graphics card tuning utility.
*Actual cooling and acoustic performance may vary by system configuration, environment, and other factors
SPECIFICATIONS
Model name
GTX650TIB-DC2OC-2GD5
GTX650TIB-DC2-2GD5
Graphics engine
NVIDIA® GeForce® GTX 650 Ti BOOST
Open GL
OpenGL 4.2
Video memory
2GB GDDR5, 6008MHz (1502MHz GDDR5)
Memory interface
192-bit
Engine clock
1085MHz
1033MHz
Outputs
DVI-I x 1, DVI-D x 1
Bundled software
ASUS GPU Tweak and driver
Dimensions
10.2-inch x 5.2-inch x 1.5-inch
