Sometimes you do not need to envy your friends with their latest expensive smartphones. Instead, you should ask yourself, why am I paying so much more for the same or similar experience.
CUBOT X18 Plus as a phablet features 5.99 inch display afford you a vivid and different visual experience. Triple cameras, 20.0MP + 2.0MP dual back cameras and 13.0MP front camera, you can enjoy images with high resolution. It comes with most of the features we’ve come to expect from a phablet, including 4GB RAM and 64GB ROM storage equipped with Android 8.0 OS that you can play games faster. Besides, 4000mAh big capacity battery affords you long time experience.
Just from the specifications, the specs is more superior than the Redmi 5 Plus and it has android 8.0 installed.
Look no further and check out the CUBOT X18 Plus smartphone which sells for only
USD 129.99 at Gearbest.com
Specifications
CUBOT X18 Plus 4G Phablet 5.99 inch Android 8.0 MTK6750T 1.5GHz Octa Core 4GB RAM 64GB ROM 4000mAh Battery 20.0MP + 2.0MP Dual Rear Cameras Fingerprint Recognition
Main Features:
Display: 5.99 inch 2160 x 1080 pixels screen
CPU: MTK6750T 1.5GHz Octa Core
System: Android 8.0
Storage: 4GB RAM + 64GB ROM
Cameras: 13.0MP front camera and 2.0MP + 20.0MP dual rear cameras with AF and flash light
Sensors: Ambient Light Sensor, Gravity Sensor, Proximity Sensor
Features: GPS, A-GPS
SIM Card: dual SIM dual standby, 1 Nano SIM card + 1 Nano SIM card and a TF card can be inserted at the same time
Networks:
GSM: 850/900/1800/1900MHz
WCDMA: 900/2100MHz
FDD-LTE: B1/B3/B7/B8/B20
