The DJI Osmo Action 6 is not just an upgrade — it is a new way of thinking about action cameras. The large 1/1.1-inch sensor helps the camera take very bright and clear photos and videos, even in low light. SuperNight mode also reduces noise, so dark scenes look much cleaner. The variable aperture gives you more control, and the camera is still very easy to use, especially with the Mimo app.
In low light, you may still see some small jitters when shooting video. The Pocket 3 can give smoother video, but it is more fragile and not as tough as the Action 6. The Action 6 is water-resistant, can be used for water sports, and is much easier to mount on bicycles, cars, and other setups.
If you need a strong all-rounder with great slow motion, good image quality, and a tough body, the Action 6 is one of the best action cameras you can buy today. But if you already own the Action 5 and you don’t need better low-light performance, you can simply continue using your Action 5 — it is still a very capable camera.
S$569 on Lazada https://c.lazada.sg/t/c.cYrjzC
- Large 1/1.1″ square sensor – Better low-light, more detail, and flexible 4K Free Cut framing.
- Variable aperture (f/2.0–f/4.0) – Brighter night shots at f/2.0 and better control in strong sunlight at f/4.0.
- Much better night performance – SuperNight mode cleans up noise and keeps more shadow detail.
- Excellent stabilization – RockSteady 3.0+ and HorizonSteady keep footage smooth and level.
- Creator-friendly workflow – Shoot once, crop later for TikTok/YouTube without flipping the camera.
- Still limited to 4K – No 5K or 8K recording.
- f/4.0 may still need ND filters in very bright scenes.
- Cropping reduces usable sensor area for some aspect ratios.
- Can heat up or drain battery faster in high-performance modes.
A 10 minute 4K/50 fps video shot with DJI OSMO ACTION 6
Check out our other video and video reviews at https://www.youtube.com/ocworkbench
