Hawx Demo benchmark on ASRock 880G Extreme3
Bluetooth 24 Apr 2010
Hawx demo is a pretty interesting game geared towards the AMD platform. In this test, we used the same methodology to test the iGPU. From the score line, it can be seen that with OC GPU, the ASRock 880G Extreme3 only scored 66 fps. With GPU set to 1GHz and sideport at 1640MHz, it shot up to 89 fps. The weird thing is that when we enabled the 4th core, the performance dip to 47 fps. This is rather unusual.
The 880 boards run well….
No display port? Really?
[…] Below is a picture of the CPU-Z, images of it running 3Dmark Vantge, hyperPI etc can be found here in the forum. You can also read the review here. […]
