First look at AMD 8 core Bulldozer processor FX-8150 with benchmarks
bluetooth 12 Oct 2011
AMD officially unveils it’s 8 Core processors the Zambezi based on Bulldozer architecture. Targetting the performance and PC enthusiasts, it is the fastest AMD processor to date to spot a new design with 8 cores.
The most anticipated model is the FX-8150, an unlocked, 8-Core processor. The FX-8150 has a 3.6GHz (base), 3.9GHz (CPU Turbo), 4.2GHz (Max Turbo) speed. It has 256K L1 instruction (64KB per module) / 128K L1 data cache (16K per module), 2MB of L2 data cache per module (8MB total L2 per processor) and 8MB (shared) L3. The total L2+L3 cache is 16MB. It has an integrated 72 bits x 2 memory controller and can support up to DDR3-1866.
The processor is based on HyperTransport 3.0 Specification with one 16-bit/16-bit link @ up to 4.4GHz full duplex (2.2GHz x2).
The packaging is the Socket AM3+ 938-pin organic micro pin grid array (micro-PGA). Max TDP is 125W.
In the next page, we will take a look at some benchmark numbers in our ongoing tests.
It has some real good numbers from the reading of the spec.
will be building another machine with this in mind for replacement.
