G.SKILL Announces Ripjaws DDR4 SO-DIMM
Up to 2800MHz 64GB (4x16GB) Ultra Speed
Taipei, Taiwan (30 October 2015) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, announces the new addition of DDR4 SO-DIMM to the Ripjaws series, with extreme performance kits at up to 2800MHz 64GB (4x16GB).
Designed for Ultra Performance and Reliability
Built only with specially screened components, hand-picked from G.SKILL’s rigorous and highly selective binning process, every Ripjaws DDR4 SO-DIMM memory kit is prudently tested to guaranteed maximum performance and reliability.
Auto-Overclocking
G.SKILL Ripjaws DDR4 SO-DIMM series features auto-overclocking, which will automatically detect and set the rated overclock speed when the memory is installed on qualified systems, so you can instantly enjoy the performance boost without having to deal with manual BIOS settings. It’s that easy.
Ultra Power Efficiency at 1.2V
Requiring only 1.2V, the Ripjaws DDR4 SO-DIMM reduces power consumption and at the same time, lowers heat output that helps your systems run cooler, more stable, and more efficiently.
Specifications
