After collecting the package, you will notice it consists of the SIMBA ONT, power adapter, 1 LAN cable and 1 Fibre Patch Cord.
Connect as follows:
The LED lights
Based on the different colour leds, you will be able to tell if your fibre network is working correctly.
The optical LED light should be stable and not blinking or no light. As for the network led, there should be blinking when data is being transmitted. If there is no light, something is wrong with the LAN network cable connection to your PC/Switch/Router.
If it can’t be resolved, it is best to contact SIMBA technical support via email. or facebook.
