Huawei IDEOS Android 2.2 smartphone Review
Huawei IDEOS Android 2.2 Smartphone
Bluetooth 11 Oct 2010
Huawei, a Chinese company made famous for it’s HSDPA dongles now brings the most affordable smartphone to the masses. Named “IDEOS”, this 2.8″ capacitive touch screen phone features the Android 2.2 Froyo ahead of other competitors in the market.
The Huawei IDEOS has been designed to be an entry level budget Android phone for the masses. This is probably you see a plastic backplate which you can replace with different colours. Although it looks pretty small, it is big in functions. Featuring a slower 528MHz processor, it is able to be used as a smartphone, a WiFi Access point. It also has a 3.2 megapixel camera which takes pictures. There is also accelerometer sensors built in for viewing text/images in both portrait and landscape mode.
The IDEOS also supports functions such as voice dialing, voice navigation, and the ability to run applications off the MicroSD memory card with the App2SD feature. With more than 70,000 applications available in Android Market,  IDEOS provides a wide range of communication, entertainment, and office and financial management applications.
Hardware Specifications of IDEOS
Standards
Display
Camera
Internal Memory
External Memory
Interfaces
Battery
Built-in Applications
Color
Dimensions (L× W× H)
Weight
* Adobe Flash Lite will be provided via Auto Update in November, 2010.
UMTS: 2100/1900/850/1700MHz
GSM/GPRS/EDGE: 850/900/1800/1900MHz
HSDPA 7.2Mb/s
2.8-inch QVGA (320 x 240) TFT Capacitive touch
screen
262K colors
Auto rotate (gravity sensor)
3.2Megapixel camera
256MB RAM + 512MB ROM
Support up to 32GB MicroSD memory card
USB port: Standard Micro USB
MicroSD memory card slot
SIM/USIM card: Standard 6-pin SIM card interface,
supporting 1.8/3V USIM card
1,200mAh rechargeable lithium battery
Working time: 5 hours max
Stand-by time: 300 hours max
Google Search?, Google Maps?, Google Calendar?,
Google Sync?, Android Market?, Gmail?, etc.
Adobe Flash Lite*
Blue, Black, Yellow, Purple
104 × 54.8 × 13.5mm
Approx. 100 grams (with battery)
Comments are closed.
